16 Boards manual assembly..
A project log for DIPSY
DIY System on Chip based on FPGA, priced below 5 USD
antti-lukatsAntti Lukats 08/14/2015 at 16:086 Comments
One full panel fresh from oven. FPGA's are soldered, one of the BGA packages has turned itself, the remaining 15 look good!
Antti Lukats wrote 08/15/2015 at 06:53 point
Actually the Programming pins are in the "MAIN" DIP8 pinout, the inner 6 pin are for small "extension board" or extra I/O there are VCC and 5 times LED IO pins in that 6 pin header.
K.C. Lee wrote 08/14/2015 at 17:28 point
BTW My way of testing connectivities:
Use multimeter diode test.  Positive terminal to Gnd, then use the negative terminal on each of the I/O lines.  This forward bias the input protection/parasitic diode for undershoot, so you should see about 0.6V for each of the I/O lines that are connected.
davedarko wrote 08/14/2015 at 17:08 point
Why don't you use a more "breadboard" friendly design? or is this fitting a special header for a programmer this way?
He has 8 pins down in a DIP configuration for breadboard, and 6 pins up for ISP.  A bit of a pin for the manufacturing folks but is specifically for breadboard friendliness.
davedarko wrote 08/14/2015 at 17:52 point
thanks for clearing it up, Mr. Lee :)
davedarko wrote 08/14/2015 at 17:53 point
came here from my feed and didn't check the project before - picture makes it totally obvious. Sry.
