FRITZING!
A project log for DIPSY
DIY System on Chip based on FPGA, priced below 5 USD
antti-lukatsAntti Lukats 09/12/2015 at 09:592 Comments
Many years have passed since I last looked at Fritzing. Nice to see many improvements. Its is really a breeze to make simple stuff. Really.
This is all you need to load a DIPSY hardware "BITSTREAM" a 30KByte binary file using TEENSY.
Amazing, and it is instantly documented the hardware setup.
And you have schematic too!
And autorouted PCB also.
And there is no need to use screen capture, all views can be saved to bitmap files.
Christoph wrote 09/12/2015 at 13:44 point
Antti Lukats wrote 09/12/2015 at 13:57 point
There is direct link to the github repo from the Project pushed to fritzing.org open project repository :)
