Licenses
A project log for USB Tester
The USB Tester makes it easy to monitor the current and voltage of any USB device (and non USB).
MobileWillMobileWill 08/11/2015 at 05:320 Comments
All the USB Tester firmware and designs are CC-SA-BY-NC. The NC part is actually only there so that if someone wanted to sell their own version I would like to be in the loop. Other than that it is open source and companies are free to use it internally. All sources are on Github for your viewing pleasure.
