More to think about
A project log for Our own BB-8 droid
Getting ready for the premiere of the last Star Wars movie, I and my son are building a 3D printed BB-8 droid
enricoEnrico 11/12/2015 at 06:433 Comments
Just found this:
It probably means other grey parts open and let other tools come out. I don't see how this can be done with a shell and a hamster movement system. It definitely requires a different propulsion system. Any suggestions?
Barry Smith wrote 01/07/2016 at 05:58 point
Moveable weights. the sphere should be fairly evenly balanced with 3 axis weights on tracks that move through the body of the droid as it moves. 6 degrees of freedom means that it should be capable of rolling in any direction (if not at brilliant speeds).
allrounder wrote 11/12/2015 at 09:30 point
Maybe having two shells, so the ball has stuff in it and then another ball inside that allows the so called hamster style movement.
Enrico wrote 11/12/2015 at 10:16 point
The problem is I'm going to use magnets to hold the head. The distance between the magnets in the body and the ones in the head should be less then 20 mm, ideally 14-15 mm.
Another problem is the alignment of the inner tools to the shell doors. The same we have in order to achieve escape mode where the head hides in the body.
