Displays
A project log for Talk Ranking Machine
Rank the talk you have just attended at a conference, by pressing one of the three buttons.
dehipudeʃhipu 08/24/2015 at 20:401 Comment
The seven-segment displays arrived today, so I should have all the required parts finally. I decided to start by getting the display to display something. Since the display has the same pin pitch as the Pro Mini, and for blue LEDs the voltage is just right, I soldered the display directly to the board, just like in #Frowney. Since I don't need the ":" sign in the middle, I left out the last 2 pins, so that only 12 pins of Pro Mini are used and I still have 6 pins for the buttons and their LEDs. A quick Arduino program to display a number:
const int GND_PINS[] = {9, 11, 12, A1};
const int VCC_PINS[] = {A0, 10, 7, 5, 4, 13, 8, 6};
const unsigned char DIGITS[] = {
    0b01111111,
    0b00000110,
    0b01011011,
    0b01001111,
    0b01100110,
    0b01101101,
    0b01111101,
    0b00000111,
    0b01111111,
    0b01101111,
void show7seg(int number) {
    unsigned char digit;
    for (int d = 0; d < 4; ++d) {
        digit = DIGITS[number % 10];
        number /= 10;
        for (int s = 0; s < 8; ++s) {
            digitalWrite(VCC_PINS[s], digit & (1 << s));
        pinMode(GND_PINS[d], OUTPUT);
        digitalWrite(GND_PINS[d], LOW);
        delay(2);
        pinMode(GND_PINS[d], INPUT);
void setup() {
        pinMode(VCC_PINS[s], OUTPUT);
void loop() {
    show7seg(1337);
And voila, it's working!
Now I just need to rework it so that it doesn't use delay(), and add the button handling.
davedarko wrote 08/24/2015 at 20:41 point
leet :)
