A list inside another list & template to copy/paste
A project log for Hack the Hack A Day Editor
A hack based on "HTML Injection". Useful when you want an online editing feature that is not available otherwise. Might work on any Website.
rogeorgeRoGeorge 07/08/2015 at 06:422 Comments
For the project Wi-Fi Reflow Oven, a list inside another list was necessary to describe all the steps for Setting up the Freescale software development tools.
Embedded lists template
How you can do it
Or, you can copy/paste a template
Most of the time, the HaD Editor will try to keep the formatting when doing a copy/paste from another page. That is why you can simply copy paste a list from another webpage into your project log, then modify it as you wish.
Alternately, you can
Or, you can simply press TAB, as [Matt] pointed out
This log entry is a perfect example of how Retardo DaVinci was I.
Just press TAB, and you will have a nested list.
Thanks [Matt], for bringing me back to Planet Earth!
:o)
Matt wrote 07/15/2015 at 11:50 point
Not too sure if this works on every browser, but in Chrome, to achieve the same thing, I hit tab in the editor when in the list and it indented my list item in one. See here for an example:
https://hackaday.io/project/4731/log/20964
RoGeorge wrote 07/15/2015 at 12:18 point
I will try it, thanks for the tip!
