Hackaday.io Hackaday.io
Sign up Log in
USB hub
A self powered USB hub with three USB ports and one serial port
andreas-dahlbergAndreas Dahlberg
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.6k views
9 comments
73 followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 9
View Gallery
3.6k
9
73
17
Team (1)
  • andreas-dahlbergAndreas Dahlberg
Join this project's team
  • Schematics
usb FT232R
Related lists
USB Keyboards
usb keyboards
HUB's
Hubs
This project was created on 03/31/2014 and last updated 12 years ago.
Description
I started this project since i needed a versatile USB hub to my Raspberry Pi. So why not make my own :) The USB hub got three USB ports and one serial port. I also got connections for 5V and 3.3V power.
Components
  • 1 × TUSB2046 4-port USB hub controller
  • 3 × SN75240PW USB port transient suppressor
  • 1 × FT232RL USB to serial IC
  • 1 × TPS2044BDRG4 Power Switch IC
  • 3 × Polyfuse
Project Logs
Collapse
  • Schematics
    Andreas Dahlberg • 04/03/2014 at 14:59 • 0 comments
    Uploaded the first version of the schematics to Github.
    https://github.com/Andreasdahlberg/HallonBox/tree/master/USB_PSU
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Mathieu Stephan wrote 03/31/2014 at 21:20 • point
if you ever go with a USB 2.0 hub i'd buy you one :)
Mathieu Stephan wrote 03/31/2014 at 20:19 • point
Any reason you opted for usb 1.1?
In case you'd like to do it with USB 2.0, you may get some inspiration from here: https://github.com/easy-phi/main/blob/master/Rack/Current%20Version/github/Kicad/Small%20Rack%205%20slots%20-%20Schematics.pdf
Andreas Dahlberg wrote 03/31/2014 at 20:28 • point
Mostly because TUSB2046B is easy to find and it also got some good documentation. USB 1.1 is good enough since i wont use the hub for any large data transfers. Looks interesting, will check it out!
Mathieu Stephan wrote 03/31/2014 at 19:10 • point
Hey Andreas, Nice project!
Which component are you using for the USB hub? the CYC smth?
Cheers
Andreas Dahlberg wrote 03/31/2014 at 20:16 • point
Hi, thanks :) I am using TUSB2046B from Texas Instruments.
Eric Evenchick wrote 03/31/2014 at 17:18 • point
This could be a very useful hacking tool! I always need more USB ports and serial. Looking forward to seeing more details.
Also, what did you render the board in? It doesn't quite look like Altium.
Andreas Dahlberg wrote 03/31/2014 at 17:36 • point
I used NI Ultiboard for the PCB layout and rendering of the design.
Eric Evenchick wrote 03/31/2014 at 17:44 • point
Ah, haven't seen renderings from it before. Looks good! Also looking forward to seeing a schematic for this, assuming you intend to open-source it.
Andreas Dahlberg wrote 03/31/2014 at 20:20 • point
Thanks! I plan to upload the schematics soon, only got some minor things left to fix first.
Rocket USB is a USB memory that can be chained one after another.
Project Owner Contributor
Rocket USB - chainable USB memory
teruteru
It's just an ornament, it can't do anything
USB Bomb
po7mn1Po7mn1
Adding USB Port to APC Back-UPS 500 ES
APC Back-UPS 500 ES USB Port Addition
rstevenson23rstevenson23
Need an extra USB port but a regular hub doesn't fit? Try my Nanohub!
Nanohub - tiny USB 2.0 and 3.0 hubs!
muxmux
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "USB hub ", please tell us the reason.
Send message
Remove Member
