Flashing for linux boot
A project log for Arduino Compatible Zynq Shield
Xilinx Zynq SoC, Arduino Compatible, 2x ARM Cortex A9, LPDDR2 Memory, USB OTG, on-board USB JTAG and UART.
antti-lukatsAntti Lukats 08/18/2015 at 21:280 Comments
https://github.com/AnttiLukats/HackaZynq/tree/master/THP2015/pre-built
there are BOOT.BIN and image.ub
call C:\\Xilinx\\SDK\\2015.2\\.\\bin\\zynq_flash.bat -f BOOT.bin -flash_type qspi_single
this will update the Flash with BOOT.BIN
note: BOOT.BIN includes: FSBL (first stage bootloader, FPGA bitstream and u-boot)
From flash only FSBL is loaded, then this FSBL loads from BOOT.BIN on SD Card
FPGA bitstream
u-boot
executes u-boot,
after that u-boot would load linux image from image.ub
note: it is possible that terminal does not accpept input, please close and open putty, this should help, there seems to be a issue that some terminal program go nuts if the say some garbage during FPGA config. We are working on this..
