Workshop @ Hackaday Hardware Superconference
A project log for Rapidly Deployable Automation System
Unfolding CubeSat rover. Mission: construction on Mars & re-construction after natural disasters on Earth. Tele-op Headband control.
erin-robotzwrrlErin RobotZwrrl 10/24/2015 at 00:550 Comments
I'm giving a workshop at the Hackaday Hardware Superconference!
Designing with Antimony for use with custom skeleton-physics simulation
Learn how to design parametric models in Antimony to make your prototyping process faster by spending less time tinkering your design with each iteration. Create complex geometric sculptures in Antimony with scripts. We will then dive into selecting key points on the geometry for use in a custom-made skeleton based physics simulation. This is helpful if you are using new materials for fabrication and need to develop your own way to simulate how it will behave under certain forces.
If you have not heard of Antimony yet, check it out! It's developed by Matt Keeter. During Fab Academy 2015 all of us students used it a lot- I became addicted to it! =)
Working on the details this weekend- will post with updates! Hope to see you there!
