Found a model for the S-video connector, added it to the render...and look at how it turned out! This 3D rendering thing is turning out to be useful for finding mistakes. Still not sending the board out to be made until the parts arrive, though.
A project log for RGB to Component/S-Video/Composite Converter
Plugs directly into an Apple IIGS, or you can adapt it to your needs.
