The models I could find for the component output connector had the pins off to the side. The CUI RCJ-32256 I've used in the past and the "Won Hung Lo" equivalents I have on order have the pins centered on each connector. I ended up taking the model for a single-jack part from CUI and cloned it in FreeCAD to get three of them, 15 mm apart. Apply color to match the Won Hung Lo connector (it has Y and Cb swapped vs. the order on the CUI connector), export it to .wrl, pull it into pcbnew, rotate and align it, and call it a day.
How is going this?
