uSupply
A digitally programmable Buck-Boost PSU with constant current capability. (0.8V-35V) output.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Based around LT3790 power IC, this allows for relatively high power control with good overcurrent measures and even constant current modes. MSP430 controller AD5280 used for digital control of feedback circuitry Voltage range might be expanded in the future if it comes as a significantly needed feature. (can be scaled to both a lower and higher Vout with a few considerations)
