Well, every journey has to have a beginning so I started of with a relatively simple part of the entire system - the UART.
Currently I have the receiver part of the UART working in theory - it's behaves correctly and can decode an incoming character when run in LTspice.
Next steps would be to prototype some parts of it at solderless breadboards followed by making some PCBs for it.
It will be a lot of transistors when the system is done, the total for the UART receiver is as follows (decoupling caps are excluded from the count)
- 1 capacitor
- 144 resistors
- 137 diodes
- 530 npn and 26 pnp transistors
The LSspice files for the UART is available at :
https://github.com/SmallRoomLabs/aytabtu/tree/master/Spice/UART
matseng
