Testing speed of D FlipFlop/Counters
A project log for AYTABTU - Discrete Computer
After the apocalypse we have to build computers from stuff we can make at home, I.E Transistors, diodes and resistors.
matsengmatseng • 08/21/2015 at 13:14•3 Comments
Now when I'm back home with a lab a bit larger than a single small desk I soldered up two versions of a edge triggered D FlipFlop.
The general schematics for NAND based Edge Triggered D FlipFlip
The first version used a single LED as the level shifter and a silicon diode as the Bake Clamp. The second version is more standard, using dual silicon diodes as level shifter and a BAT54 Schottky as the Baker clamp.
When simulated in LTspice both version can (when configure as divide-by-2's) can work up to a bit more than 4 MHz. The LED/Si version was just a little bit slower than the 2Si/Sch, just a few % difference.
But in real hardware the story was quite a bit different.
The LED/Si version only worked up to 180 KHz at 3.3 volts, when lowered to 2.5 volts the max speed rose to 210 KHz. Very slow and basically unusable for building the four-phase clock generator for the CPU.
The 2Si/Schottky version did better. 550 KHz at 3.3 volts and 720 Khz at 2.5 volts.
But this still about an order of magnitude slower than simulated. So I need to work on getting the speed up quite a bit before I send for any of the PCBs I've designed the last two weeks. :-(
The LED/Si version
Yann Guidon / YGDES wrote 03/31/2016 at 04:34 • point
I don't see any decoupling...
matseng wrote 03/31/2016 at 05:23 • point
The top board was without decoupling. The bottom one got caps soldered between the rails before testing....
matseng wrote 08/23/2015 at 03:42 • point
Just simplifying the layout a bit by putting multiple parts into the same hole. This both saves space and reduces the soldering time.  And it was just test circuit on a very small pcb, so I won't keep it for any real use.
Maybe it was the confused layout that made the electrons dizzy and slow here.. :-)
