IRIS firmware/sdcard images repository, build log, PCB's
A project log for IRIS - network radio with alarm clock
IRIS is yet another network radio based on Rasbperry Pi. This time with an alarm clock and some reading skills.
woytekmwoytekm 10/06/2015 at 10:290 Comments
Sdcard and firmware images are here (github.com). Minimum reasonable setup required to run this firmware is Raspberry Pi, NVRAM+RTC module, wifi stick, and some sound source - headphones, speaker or bluetooth speaker (BT stick required). In the next few days i'll try to create a photo build log, and separate github repository with EAGLE PCB files for the entire project.
