Features:
A project log for Teensy 3.1 SMD Reflow Oven Controller
Designed For Nextion HMI TFT Use
charles-lakinsCharles Lakins 07/08/2015 at 18:200 Comments
Features:
* 1 x i2c input for display or sensors - pins A4(SDA), A5(SCL)
* 1 x Serial output for display or blutooth module (Nextion TFT HMI) - pins RX3, TX3
* 3 x Solid State Relay pins (5v & 12v-Selectable pads & GND switched via transistors) - pins 2. 3. 4
* 1 x 12v PWM fan connection - pin 5(TX1/PWM)
* 1 x Sense amplifier IC for a K-type thermocouple. - pins 12(DIN), 10(!CS), T-, T+, 13(LED/IC pin5)
BOM:
* C1 0805 0.1uf Capacitor
* D1 SMA B130 Diode
* Q1 SOT23 MMBT2222A SOT-23 NPN (6V / 750 / 40V 600MA)
* Q2 SOT23 MMBT2222A SOT-23 NPN (6V / 750 / 40V 600MA)
* Q3 SOT23 MMBT2222A SOT-23 NPN (6V / 750 / 40V 600MA)
* R1 R0805 1k Resistor
* R2 R0805 1k Resistor
* R3 R0805 1k Resistor
* R4 R0805 100k Resistor
* R5 R0805 100k Resistor
* R6 R0805 100k Resistor
* U$1 TEENSY3.1
* U$2 MAX6675 SO08 IC
* Momentary Tact 4pin 4x4x1.5mm SMD
