I've been working on mapping 2016 year model of worx, they use DB504 motherboard. Usually .pck-firmware, its a container and the start is plain-text. It's possible to do a splitter for that but I use dd to copy out the firmware.
DB504 probably use LPC1788. I've been looking on some io's on a picture I've recieved and it seams to be correct. (not possible to read chip text without removing the conformal coating)
Display and Keyboard are the same as previous models. Wire sensor uses a daughter board:
Should we assume they still uses LPC and that this might be an LPC11U6x?
( https://www.ghielectronics.com/catalog/product/282 looks like a suspect...)
So far I've been developing and reversing DB275 (2015 WG790/791/794) It seams all 2016 has DB504.
WG796e (2015) uses DB297 which I haven't seen yet. So if any one wants to send in pictures of that motherboard it would be very appreciated!
I don't know much about earlier versions.
//Daniel
edit:
Daniel Wiegert
added new pic
The Sonic pads looks interesting. Do you know what it says under the blob?
