Noon Pacific 7/21/15 or 21/07/15 update
A project log for Functional Pipboy controller for Fallout
Plan on turning a controller into a Pipboy for Fallout. The Pipboy would be fully functional for a player.
karlKarl 07/21/2015 at 19:410 Comments
7/21/15 update
Purchased a soldering kit (this will be my second time
ever holding a hot soldering iron so... w00t w00t) 4 buttons, 2 feet of
8(?) strand copper wire and a Gamestop "authorized" Xbox 360 controller.
My intention for today is to solder the wires to the new buttons. I will
open the controller, bottom up, and stabilize it,then plug it into comp
in place of current troller.
Once done with that I'll press the
wires from new buttons to the circruit board and attempt to utilize the
new button, one at a time, to mimic the actual controller buttons
WITHOUT SOLDERING TO THE MOTHERBOARD <--
Since I'm a complete noob to soldering it would be the height of stupidity or arrogance to
assume I could solder to a working motherboard first time out. Soldering
to the buttons is no sweat as it's two separate pins of metal far
enough apart I can work and flub up as much as I need to learn finer
soldering points. Also, by just finger pressing the wire to the circuit
board I'm not damaging the board in anyway so if I decide I don't like
these buttons, or need to change this, that or the other thing, I can.
If this works I've already found some old 1950's tech pieces to complete
the look of the switches and dials on the Pipboy's face, but
transforming those into rocker switch input should be difficult enough.
I'll chk back for replies before I begin soldering later on, maybe 2 hours or so. If you've got soldering tips, do it now :)
