// Parking Helper
// by Hari Wiguna, 2015
// Heavily based on Arduino Ping example
const int ON = LOW;
const int OFF = HIGH;
// Distance sensor is HC-SR04
const int pingPin = 12; // TRIG
const int echoPin = 13; // ECHO
int prevBar = 0;
void setup() {
  //-- Initialize led bargraph pins (D2..D11) --
  for (int i = 0; i < 10; i++)
    pinMode(2 + i, OUTPUT);
    digitalWrite(2 + i, OFF);
  //-- Initialize distance sensor pins --
  pinMode(pingPin, OUTPUT);
  pinMode(echoPin, INPUT);
void loop()
  // Send out a 5 microsecond pulse
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  digitalWrite(pingPin, LOW);
  // Listen for that pulse to come back
  long duration = pulseIn(echoPin, HIGH);
  // convert the time into a distance
  long cm = microsecondsToCentimeters(duration);
  // Convert cm to bar graph
  int bar = map(cm, 10, 70, 9, 0);
  // only update bar graph if value changed
  if (bar != prevBar) {
    digitalWrite(2 + prevBar, OFF);
    digitalWrite(2 + bar, ON);
    prevBar = bar;
  delay(100);
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
