Hackaday.io Hackaday.io
Sign up Log in
Modular Synthesizer Controller Keyboard Case
3d print your own synthesizer controller! Multiple sections fit together so you can expand it as much as you need!
tina-belmontTina Belmont
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
5.1k views
8 comments
430 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 8
  • The 2015 Hackaday Prize
View Gallery
5.1k
8
430
38
Team (2)
  • tina-belmontTina Belmont
  • pat-morrisseyPat Morrissey
Join this project's team
  • Pinshape
ongoing project
synthesizer 3d printing model keyboard controller Synth MUSIC Instrument 2015HackadayPrize
Related lists
2015 Hackaday Prize: Quarterfinalists
Projects that were officially submitted to the 2015 Hackaday Prize
Unique Music Playback
Everyone has a phone; build something special to play your tunes.
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 07/11/2015 and last updated 5 years ago.
Description
Multi-part design for synthesizer controller keyboard, the DIY synthesizer designer's dream!
Modular design allows you to print as many sections as you need. Need another octave of keys? Print all you want? Want 5 modulation wheels? You can do it!
This design has many useful features for the DIY synthesizer designer! The front panel has a grid embossed on the back for easy drilling of holes for knobs and sliders; never worry about the drill sliding away from you again! The bottom includes mounting holes for screwing down circuit boards. The edges have grooves in them so that the parts will not jump out of alignment. The whole design is designed to be fastened together at the ends with threaded rods through all of the parts.
The parts are currently designed at a very small scale so that you can scale it up to any size that you need.
You can currently download it from Pinshape.
Project Logs
Collapse
  • Some test prints...
    Tina Belmont • 10/14/2015 at 10:14 • 0 comments
    Theron at Crashspace in Culver City was nice enough to print out a few of the newly repaired parts for me! Thank you so much, Theron!
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Tina Belmont wrote 10/11/2015 at 09:20 • point
Hey, a lot of folks complained about non-manifold geometry, and for a long time I was powerless to fix it. But recently I got Windows 10 and it came with "3D Builder" which seemed to do a decent job of repairing the files! So if anybody wants to give it a shot again, I've reuploaded everything to Pinshape here: https://pinshape.com/items/7200-3d-printed-modular-synthesizer-control-keyboard
cris wrote 10/05/2015 at 20:50 • point
Hi,
Very excited about this, and my 8yo has just started playing piano!
But, I downloaded and unzipped and starting with the black and white keys, there is something wrong with the files - they don't slice properly...
Has anyone sucessfully printed them?  How did you get them to print?
Cris.
Tina Belmont wrote 10/06/2015 at 21:20 • point
I think the Windows 10 3D Builder might be able to repair and print it. I'm going to test it on that soon.
All of the other programs can't seem to handle the overlapping geometry that SketchUp created.
cris wrote 10/06/2015 at 22:54 • point
Bingo.  I'm not in a rush, but if you like, I'll post a set of fixed files in a week or so...
OK.  so that's not a week...  I have a set of repaired files, shall I upload them to thingiverse?
Cris.
Tina Belmont wrote 10/11/2015 at 09:19 • point
I ran the repair and uploaded to Pinshape here: https://pinshape.com/items/7200-3d-printed-modular-synthesizer-control-keyboard
I suspect these might have funky holes, but it might work now.
Did you get a chance to print your repair? Did it work?
Tina Belmont wrote 07/15/2015 at 10:32 • point
Thanks!
Me too! But I didn't find one so I made my own instead!
I based it on consumer portable keyboards from Casio, Yamaha, etc. They all seemed to use a rubber bubble sheet with metalized contacts that touch on a circuit board that matches the shape of the keys. I don't know how to fabricate that yet, so I left it as an "exercise for the reader". One could just put contact screws on the bottom of the keys to bridge connections on the circuit board for a similar idea, although the feel wouldn't be great.. Probably standard pushbuttons would be the easiest way to start.
I have a newer, unfinished design that actually puts holes in the keys to run wires through, but it isn't ready for prime-time yet.
Please let me know how it comes out if you try to print it!
DL101 wrote 07/18/2015 at 16:11 • point
Hi
Here is one idea:
http://www.ebay.com/itm/28pcs-CHERRY-MX-Series-key-Switches-red-Axis-shaft-3-pin-original-mechanical-/331562111450?pt=LH_DefaultDomain_0&hash=item4d32a451da
Those could be mounded on a PCB directly under the key, and it would also support the key itself, and give it a proper feeling when being pressed.
Another option is this:
http://www.ebay.com/itm/10PCS-Micro-Switch-Spdt-Hinge-Roller-Lever-15A-V-156-1C25-/221534897913?pt=LH_DefaultDomain_0&hash=item33948246f9
Microswitches would also do well, but those would require doing a custom holder for the switch, and a PCB might be difficult to do for this one.
I am out of resources for printing at the moment, the hackerspace is closed for the summer.
I already did a synth project once, here it is:
https://hackaday.io/project/375-diy-mini-midi-synth
But as you can see, it uses cheapo buttons, and those are awful!
They miss contact a lot, so even if you keep them pressed, if you don't apply enough force, they will loose contact for a moment, causing a keypress to be registred, which is really annoying!
I could try making a PCB layout for that, with cherry mx switches to fit on the keys, but I don't have the money at the moment to order/buy/print anything at all. But if I do that, I think the keys will require some adjustment to allow the switch to fit nicely in the key. I am no 3d modeler, so I am hopeless there.
DL101 wrote 07/14/2015 at 07:13 • point
Finally, I've been looking for synth keyboards for years now!
It still does not have the switches, something like charry MX might work, but an more inexpensive alternative would be better.
Stylish 3D printed replacement for a 2003 Honda Odyssey A/C control knob
Project Owner Contributor
3D Printed Honda Odyssey Replacement Knob
will-kalmanWill Kalman
Reviving a set of headphones with some CAD work and 3D printed parts
3D Printed Beats MIXR repair
trysten-den-hartogTrysten Den Hartog
The need is real to replace the missing handle to the attic stairs!
Regain access to the attic staircase
frankFrank
A small(er) Vortex Particle separator that can be easily 3D printed. Use with a 2" or 1.25" (adapters needed - can be printed) vacuum hose.
3D Printed Vortex Particle Separator for Shop Vac
aaron-pAaron P.
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Modular Synthesizer Controller Keyboard Case", please tell us the reason.
Send message
Remove Member
