Design Failure
A project log for 3d printed gopro steadicam
gopro steadicam with mostly 3d printed parts
russell-hayRussell Hay 04/08/2014 at 15:270 Comments
So the current design that I was working with was a failure.  The axles are too small to be reliable/robust, so I think I will need to rethink my design and probably use metal axles, which also means I probably should just design it to use bearings at all rotation points.  Or at least delrin bushings to reduce friction.
So I'm back to the drawing board on this one, but failure is a part of learning.
