Super Simple Load Driver Circuit
Turn loads on and off with your Micro! Use 5V to control up to 100V. Add a motor, solenoid, or get creative! P channel or N Channel.
This is a super simple circuit to control loads using a small amount of power from a microcontroller. With the use of 2 N-channel MOSFET's and 2 P-Channel MOSFET's it is possible to build a very simple H-Bridge driver. This allows you to control the Polarity/direction of a DC motor.
Check out the kickstarter project to get your MOSFET Breakout board today. I need your support!
https://www.kickstarter.com/projects/323660810/super-simple-arduino-load-driver-v20-now-control-p
Casey Halverson wrote 07/16/2015 at 01:15 point
Perfect match with the ESP8266!
