Now for wiring up.
I also spent most of the day working out how to software control the spindle speed. The spindle controller board has pins for this (PWM) but not clear details on the function of the pins.
I first replaced the connectors to ones I can work with.
I did some quick reverse engineering of the spindle controller and hope to try this out at a later time.
Johnny
