While it was advertised as SOFT-PROPELLER, it was not until today it actually works as a Propeller.
Testing on Parallax Development Board, flashed the SPIN code into EEPROM on Parallax board, and well Soft-Propeller configures itself from SPI flash as propeller and then loads prop code from EEPROM.
Soft-Propeller has no on-board EEPROM, but this can be emulated in FPGA there are enough block rams free.
Utilzation:
FF: 15%
LUT: 50%
BRAM; 33%
Antti Lukats
