HW & SW update & upgrade
07/30/2015 at 09:56 • 0 commentsReceived perfboards and started moving nodes from breadboard to a perfboard. Never done this before, takes huge amount of time. I also discovered that the automatic temperature regulation does not work on my iron so I can solder only a certain time before it goes insanely hot.
I also tided up the code. It's a bit more stable.
Smashin' bugs
07/22/2015 at 20:20 • 0 commentsToday was a busy day and quite a lot was fixed
- Nodes now send their RF24Mesh ID with the payload to make my life easier
- Added new header to sort out PIR sensor updates
- Tidied up code, merged common code into a library all sketches include
Software updates, yay!
07/20/2015 at 20:12 • 0 comments- Almost all nodes now have fully functional code
- Time is synced from one node to other nodes
- GUI code has been cleaned up, it is ready for the new software
- Rearranged sensors and outputs nodes had
