LPDDR2 Tests OK
08/13/2015 at 17:28 • 0 commentsOur first board with Zynq and LPDDR2 seems to have no issues with the DDR memory, so this is go for this project as well.
There are problems with Xilinx Vivado and LPDDR2 configuration, but those problems are not a show stopper.
Project created :)
07/18/2015 at 08:46 • 0 commentsPrimary design choiced are made: Pinout is kept compatible to little brother Soft Propeller.
Added Features
- 32MByte LPDDR2
- USB PHY and micro-USB Connector
- microHDMI Connector
Removed features
- Pin headers on the top (3 times 2x5) are removed
Decisions to make:
PCB Technology - target tech is currently 1+6+1 HDI, no stacked via, no via fill, no via in pad. This should be sufficient, but will be finalized during preliminary routing.
DCDC Converters, as there are now many more components in about same area as Soft Propeller v1.0, it may be necessary to change some DCDC converters to smaller footprint ones at the expense of higher cost.
It is open if the si1143 based 2D gesture support can remain, maybe :)
Authors commentary:
I have had some very similar drawn in sketchbook for decades. It has had different names, one I remember was "panncake computer". I think the panncake computer design was targeting about same used PCB area as DIP40 does. Well the list features and possible uses was not comparable to what is possible today.
It feels like right time to do it. Now.
This project depends on two other projects:
https://hackaday.io/project/6786-soft-propeller
Soft Propeller, where I have working PCBs already, so a lot designs and project and software can be tested in advance.
https://hackaday.io/project/6633-arduino-compatible-zynq-shield
Arduino compatible Zynq Shield. Those PCB will arrive in a few days, so I can test out the LPDDR2, this is important to have proven working before finalizing the he PCB for this project.
