Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
DIY JTAG progammer for CPLD board
Companion project to my DIY CPLD board project here
hackhead79hackhead79
Following Follow project
Liked Like project
Become a Hackaday.io member
Not a member? You should Sign Up.
Already have an account? Log In.
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
3 followers
  • Description
  • Details
  • Files 0
  • Components 3
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 1
783
1
3
1
Team (1)
  • hackhead79hackhead79
Join this project's team
ongoing project
This project was created on 04/02/2014 and last updated 6 years ago.
Description
This is a prerequisite project to my DIY CPLD project here on hackaday.io.
The CPLD board needs a means of being programmed: hence this project to build the matching programmer for the board.
For this I'll follow the tutorial on startingelectronics.com (http://startingelectronics.com/projects/xilinx-parallel-programmer/ ).
Components
  • 2 × 74LVX 125 D Quad 3-state buffer as a replacement to the 74HC125N needed for the tutorial
  • 1 × set for 14-pin ribbon cable including plugs
  • 1 × a few other components - see tutorial
Project Logs
Collapse logs
  • Only a few updates here
    hackhead79 • 04/02/2014 at 20:50 • 0 comments
    Most of the updates will be found at my other project (DIY CPLD board). I'll post a few updates of the PCB making process here though.
View project log
Log In/Sign up to comment
Sign up with Github
OR
Peter Burkimsher wrote 06/30/2014 at 19:35 • point
The parallel programmer is great for desktops, but I have a laptop without a parallel port.
I'm using the gz_load program from the GuzuntyPi project on my Raspberry Pi, which works to program 3.3V JTAG.
https://github.com/Guzunty/Pi/wiki
I also have an FPGA, but that uses 2.5V JTAG. Building a voltage level converter for that is an ongoing project for me!
My Digital Electronics class is building a programmable board with various sensors to experiment on.
Project Owner Contributor
Patriots Companion
XaiXai
Fork of the project Nyan Board for make earrings
NyanCatEarrings
SabasSabas
In old PCB's i found a low-capacity FPGA(CPLD) - EPM7064. I decided to make a small evaluation board.
The FPGA evaluation board - Frankenstein
AlexAlex
A project in waiting...
STEbus Z280 board
KeithKeith
Going up?
© 2021 Hackaday
Yes, delete it Cancel
You are about to report the project "DIY JTAG progammer for CPLD board", please tell us the reason.
Send message
Remove Member
