ESP8266 notifications via Pushetta
Fast example on notifications
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
sendToPushetta(CHANNEL, "Hello world!");
With only a few lines of code you can add this functionality to your ESP8266. For the result, check the pic. It's a great way of pushing notifications to your devices, easy and fast to add to your current project. Want a notification when someone goes in front of your PIR? Check. Want a notification when your ESP8266 is running low on battery? Check. Want a notification when your devices connect to a network? Check.
Source code: https://github.com/Astu04/Pushetta_ESP8266
