| ESP8266 Breakout Board, Bill of Materials |
| Id | Designator | Package | Quantity | Designation | Description | Mfr. Package | Mfr. | Mfr. P/N | Dist. | Dist P/N | Price/1 | Link |
| 1 | C1,C2 | Capacitor5x6RM2.5 | 2 | 10uF | CAP ALUM 10UF 20% 25V RADIAL | Pitch : 0.098" (2.50mm) 0.157" Dia (4.00mm) x 0.276" Height (7.00mm) |
Panasonic Electronic Components | EEA-GA1E100H | Digikey | P15799CT-ND | 0.35 | http://www.digikey.com/product-detail/en/EEA-GA1E100H/P15799CT-ND/3831166 |
| 2 | D1 | LED-3MM | 1 | LED | LED 3MM HI-EFF RED DIFFUSED | Round with Domed Top, 3mm (T-1), 3.00mm | Lite-On Inc | LTL-4221N | Digikey | 160-1139-ND | 0.33 | http://www.digikey.com/product-detail/en/LTL-4221N/160-1139-ND/214530 |
| 3 | P1 | Pin_Header_Straight_1x03 | 1 | V_SEL | CONN HEADER .100" SNGL STR 10POS | Pitch=0.100" (2.54mm) Number of Rows=1 Through Hole |
Sullins Connector Solutions | PRPC010SAAN-RC | Digikey | S1011EC-10-ND | 0.3 | http://www.digikey.com/product-detail/en/PRPC010SAAN-RC/S1011EC-10-ND/2775244 |
| 4 | P2 | Pin_Header_Straight_1x06 | 1 | FTDI | As above | |||||||
| 5 | P4 | Pin_Header_Straight_1x03 | 1 | TX_SEL | As above | |||||||
| 6 | P3 | Pin_Header_Straight_2x04 | 1 | ESP-01 | CONN HEADER 8POS .100 STR TIN | Pitch=0.100" (2.54mm) Number of Rows=2 Row Spacing=0.100" (2.54mm) Through Hole |
FCI | 67996-408HLF | Digikey | 609-3391-ND | 0.32 | http://www.digikey.com/product-detail/en/67996-408HLF/609-3391-ND/1487877 |
| 7 | R1 | Resistor_Horizontal_RM10mm | 1 | 1k | RES 1K OHM 1/4W 5% CARBON FILM | 0.091" Dia x 0.256" L (2.30mm x 6.50mm) | Stackpole Electronics Inc | CF14JT1K00 | Digikey | CF14JT1K00CT-ND | 0.1 | http://www.digikey.com/product-detail/en/CF14JT1K00/CF14JT1K00CT-ND/1830350 |
| 8 | R2,R3,R4,R5 | Resistor_Horizontal_RM10mm | 4 | 10k | RES 10K OHM 1/4W 5% CARBON FILM | 0.091" Dia x 0.256" L (2.30mm x 6.50mm) | Stackpole Electronics Inc | CF14JT10K0 | Digikey | CF14JT10K0CT-ND | 0.1 | http://www.digikey.com/product-detail/en/CF14JT10K0/CF14JT10K0CT-ND/1830374 |
| 9 | R6 | Resistor_Horizontal_RM10mm | 1 | 1k8 | RES 1.8K OHM 1/4W 5% CARBON FILM | 0.091" Dia x 0.256" L (2.30mm x 6.50mm) | Stackpole Electronics Inc | CF14JT1K80 | Digikey | CF14JT1K80CT-ND | 0.1 | http://www.digikey.com/product-detail/en/CF14JT1K80/CF14JT1K80CT-ND/1830356 |
| 10 | SW1 | SW_PUSH_SMALL | 1 | RST | SWITCH TACTILE SPST-NO 0.05A 24V | 6.00mm x 6.00mm | TE Connectivity Alcoswitch Switches | 1825910-7 | Digikey | 450-1804-ND | 0.1 | http://www.digikey.com/product-detail/en/1825910-7/450-1804-ND/1731414 |
| 11 | SW2 | SW_PUSH_SMALL | 1 | GIPO0 | SWITCH TACTILE SPST-NO 0.05A 24V | 6.00mm x 6.00mm | TE Connectivity Alcoswitch Switches | 1825910-7 | Digikey | 450-1804-ND | 0.1 | http://www.digikey.com/product-detail/en/1825910-7/450-1804-ND/1731414 |
| 12 | U1 | A1117 | 1 | AP1117D33 | IC REG LDO 3.3V 0.8A TO220AB | TO-220-3 | STMicroelectronics | LD1117V33 | Digikey | 497-1491-5-ND | 0.62 | http://www.digikey.com/product-detail/en/LD1117V33/497-1491-5-ND/586012 |
| 13 | - | Shorting Links, Jumpers | 2 | -- | SHUNT JUMPER .1" BLACK GOLD | (1 x 2), Pitch=0.100" (2.54mm) | 3M | 969102-0000-DA | Digikey | 3M9580-ND | 0.1 | http://www.digikey.com/product-detail/en/969102-0000-DA/3M9580-ND/2071621 |
Anool Mahidharia
ACROBOTIC Industries
Tirdad sadri nejad
Bruce Land
