CNC_jogger.inoArduino-based software for manually controlling my CNC machine. Niew, slightly improved version (December 2016)x-arduino - 25.80 kB - 01/07/2017 at 12:08 |
analogKeypad.hThe header of the analog-keypad library used for my machinex-chdr - 956.00 bytes - 07/24/2016 at 15:37 |
analogKeypad.cppThe .cpp of the analog-keypad library used for my machinex-c++src - 3.00 kB - 07/24/2016 at 15:36 |
numericDisplay.hThe header of the arduino-library for showing my position numbersx-chdr - 569.00 bytes - 07/24/2016 at 15:36 |
numericDisplay.cppThe .cpp of the arduino-library for showing my position numbersx-c++src - 3.74 kB - 07/24/2016 at 15:35 |
CNC-mill_freecad.fcstdThe mill as freeCAD design.x-extension-fcstd - 168.01 kB - 07/24/2016 at 15:33 |
PCB_milling_precision_test.svgThe .svg file of the test-pattern. You can use the plugin "gcodetools" to create g-code from that pattern. Note that the milling-speed for the speed-test was changed with a text-editor afterwards.svg+xml - 29.37 kB - 03/02/2016 at 08:18 |
PCB_milling_precision_test.ngcThis is the G-code for the test-pattern shown in my second Follow-up video.ngc - 11.29 kB - 03/02/2016 at 08:12 |
