Another diagnostic port option
A project log for GPS Disciplined xCXO
A DIY GPS disciplined 10 MHz reference clock
nick-sayerNick Sayer 11/28/2017 at 17:520 Comments
If you need to connect the diagnostic port up to RS-232, there's an adapter board design you can use. You can select whether the transmit pin is the diagnostic output or the GPS NMEA output. Received data is connected to GPS. The PPS output is connected to DCD and is configured so that DCD asserts on-time.
