Production equipment #2
A project log for PowerPeg Thermal Management System
SMT Thermal Connector System
Dean GouramanisDean Gouramanis 11/07/2015 at 11:101 Comment
This machine cuts a thin layer from the front surface of PowerPeg, making it perfectly flat.
The machine consists of a motorized clamp, and an air-powered broach. When the air piston is actuated, the copper part is dragged past a carbide blade.
The result is a curled copper circle, only 0.005" thick. The finished surface is flat and shiny.
esot.eric wrote 11/07/2015 at 17:39 point
whoa, that ain't the mill I was expecting from the first sentence... nice.
