I will have to setup the server better so as temporary solution here quick links:
- September 2008
- October 2008
- November 2008
- December 2008
- January 2009
- February 2009
- Embedded World 2009
- March 2009
- April 2009
- June 2009
- July 2009
- August 2009
If you like anything in those "oldies" please consider to join either #DIPSY or #Soft Propeller projects at HaD.
Note: the PDF isssues are "snapshot" of what I found on backup HDD. They are not post modified from the originals - there are dead-links inside, and the last issue, is well "thin", but I included it anyway.
Thank you
Antti
I read three issues, but it looks great. Goldmine of information here.
Just curious - in october 2008 issue, on page 12 you do mention ARTI interpreter on PIC16C84. That looks interesting. I tried to google it, but no luck. Do you think you could release it, please?
ARTI, yes now I remember the name too. I was trying to figure out how it was called - I may find it, but I need to go way more back in time for this. If its found will post it her.
What is KNOWN and coming is BlinkOR - its Code that can be read and written by humans and directly executed by machines, NO TRANSLATION either way.
Oh great, I see you are actively doing a lot of projects at the same time, awesome. I have also a lot of projects, but I'm not doing them, unfortunately.
Anyway, I'm following you, so no news from you will escape me. Thanks.
so-so yes at the border zone
Amazing ... was that from your #Freelance/Independant times ?
