close-circle
Antti-Brain past issues 2008-2009
A project log for ANTTI BIBLE
A Bible - you can either read one or write one. I am writing it. My name is Antti.
Antti Lukats 08/30/2015 at 10:095 Comments
I will have to setup the server better so as temporary solution here quick links:
If you like anything in those "oldies" please consider to join either #DIPSY or #Soft Propeller projects at HaD.
Note: the PDF isssues are "snapshot" of what I found on backup HDD. They are not post modified from the originals - there are dead-links inside, and the last issue, is well "thin", but I included it anyway.
Thank you
Antti
jaromir.sukuba wrote 08/30/2015 at 11:28 point
I read three issues, but it looks great. Goldmine of information here.
Just curious - in october 2008 issue, on page 12 you do mention ARTI interpreter on PIC16C84. That looks  interesting. I tried to google it, but no luck. Do you think you could release it, please?
Antti Lukats wrote 08/30/2015 at 11:35 point
ARTI, yes now I remember the name too. I was trying to figure out how it was called - I may find it, but I need to go way more back in time for this. If its found will post it her.
What is KNOWN and coming is BlinkOR - its Code that can be read and written by humans and directly executed by machines, NO TRANSLATION either way.
jaromir.sukuba wrote 08/30/2015 at 11:42 point
Oh great, I see you are actively doing a lot of projects at the same time, awesome. I have also a lot of projects, but I'm not doing them, unfortunately.
Anyway, I'm following you, so no news from you will escape me. Thanks.
Antti Lukats wrote 08/30/2015 at 11:07 point
so-so yes at the border zone
Dimitar Tomov wrote 08/30/2015 at 11:02 point
Amazing ... was that from your #Freelance/Independant times ?
