Some new videos
A project log for Drum Master
Electric drum set based on Teensy 3.1 and Audio Board
The Big OneThe Big One 12/25/2015 at 05:320 Comments
Below are two new videos I shot today. One shows the entire kit, the other shows the new hihat samples. The new hihat samples have more variation between closed and open states (9 levels vs 5), and the open samples are not artificially cut short.
At this point I am pretty much finished... There are some bugs in the menu system that I need to work on, but the playback seems to be working fairly well. As I actually play there will doubtless be some tweaks, but so far so good.
Cheers
