Bass Pedal Mount
A project log for Drum Master
Electric drum set based on Teensy 3.1 and Audio Board
the-big-oneThe Big One 11/29/2015 at 03:240 Comments
I finished the bass pedal mounting hardware today. This lets you attach a normal bass pedal in the right position. It is very simple, consisting of just a metal rod stuck in the middle of a wooden piece, with another wooden piece mounted at a right angle which attaches to the main kit frame.
A picture is worth a thousand words, so read on for the four thousand word explanation:
