life-size
A project log for 2.5-3D thing
a tiny-but-scalable three-ish axis-system *from* laser-cuts
eric-hertzEric Hertz 08/27/2015 at 02:579 Comments
ah.
So this is roughly life-size...
The teeth, then, are like... *maybe* 1mm at their widest. and, unless I do everything *just* right (yeah, right... especially not from a [low-resolution] photograph) it seems most-likely I'll only really have one tooth making contact at a time... starting to seem a little bit ridiculous.
I am proud, however; I used a different technique to get real-world measurements from the image for the motor-assembly than for the gear/tooth-spacing, and they seem to align.
As far as material... I dunno what to think. I haven't worked with "modeller's plywood" before, but it's hard to imagine the grains crossing the teeth wouldn't be tempted to fall out at these tiny sizes. And, acrylic, well, that's known to be brittle, so probably all the force on a single tooth jutting out at nearly 90deg isn't such a great idea.
Paul McClay wrote 06/18/2022 at 18:04 point
This is an old log entry but anyhow...
I've found tiny acrylic gear teeth to be astonishingly durable, relative to expectations similar to what you wrote. I suppose it's the same sort of material property scaling as ants carrying 10^n x bodyweight on spindly legs. That's entirely subjective, but I suspect that if you made a gear that worked geometrically, this application would neither break it nor wear it out.
Eric Hertz wrote 06/19/2022 at 03:57 point
Interesting. And a good, memorable, example. I'll keep that in mind for future eneavors, even if I never come back to this one, specifically.
Please, don't hesitate to leave comments on old posts, mine at least!
Eric Hertz wrote 06/19/2022 at 04:00 point
Ah, but... the only reason I *shouldn't* encourage that is because HaD's email throttling means I'll miss them if you were to say comment on post after post. I feel bad stumbling on years-old comments I never knew were there :/
Paul McClay wrote 06/19/2022 at 05:05 point
same. missed opportunities. :(
Eric Hertz wrote 10/26/2022 at 01:58 point
Behold! I've just learned of "My Notifications"!
Click the drop-down in the upper-left, Then, weirdly, under "My Profile". At least, here, it also eventually shows a brightly-colored number which grabs attention if you wait several seconds.
Maybe we'll see a decrease in Missed-Opportunities, and maybe even some found!
Paul McClay wrote 11/04/2022 at 07:56 point
Yeah, there's that. Another dopamine drip!
I'm pretty sure I've had some notifiable events never show up there tho...
Paul McClay wrote 11/04/2022 at 08:03 point
...in fact I *just now* saw (didn't see) a notification that I know I saw before disappear from the list.
And now it's back...
Eric Hertz wrote 11/04/2022 at 21:31 point
Hah, disappearing/reappearing notifications might be one way to hack a [person's] day.
Paul McClay wrote 11/06/2022 at 00:52 point
...and right now I have two HaD tabs with different notification lists, even after reloads of each.
