Build Plate
A project log for OpenBuilds C-Beamâ„¢ Machine Build
C-Beam Machine is a CNC machine design based on the popular V-Slot linear guide system.
charliexcharliex 07/27/2015 at 00:370 Comments
For the build plate, it is going to be
Clean the 500 mm C beam of swarf, check for issues where the wheels will track.
Take the build plate and drill out the 8 out-most holes to 6 mm so that the self tapping screws will just pass thru, this is where the MDF or such mounts and rather than do it later when the wheels and nut runner is installed, so less chance of getting swarf into them. Countersink the holes a little, just to knock out the edges.
Build the wheel kits
Same as before
Take note of orientation of the build plate, install two with eccentrics, two with 6 mm spacers. 25 mm bolts
Both on with 6 mm spacers
Eccentric side 2 mm bolts
Install the wheel kits, 1 mm spacer on top of the 6 mm spacer, and samee on the eccentrics spacers, add wheels then the nut and tighten
Anti-back lash nut, I've already installed the set screw and holding nut here.
Install the bolts for the nut screw so the lead screw would be centered
Add the nuts to the holders.
Clean out the nut again, this one was the worst of the bunch so far, I could barely thread it the start, and also had to treat the threads on the lead screw where they've been cut, small file again to clean up the edges. Ended up with the cordless drill slowly moving the lead screw back and forward after about 10 cycles by hand first.
This is the result
Next add the gantry plate to the last 500 mm C Beam, adjust the eccentrics as before, so nice and tight and no slop.
Next step is prepping the MDF for mounting and waste board. Then building the frame out.
