Braces, onto the frame
A project log for OpenBuilds C-Beamâ„¢ Machine Build
C-Beam Machine is a CNC machine design based on the popular V-Slot linear guide system.
charliexcharliex 07/27/2015 at 04:360 Comments
Part list
install the corner brackets with a T-Nut and 10 mm bolts on the C Beam
install left side mount plate with 4 M4 20 mm
I found it easier to install the lead screw with the gantry off the C Beam
install the bearing, add the washer round side towards bearing, and the lock collar, fit it all in, flush the lead screw
install the other side now
leave a small gap on the mounting plate, don't tighten the 20 mm M4's all the way
push it all together, lock the collar and then tighten down the plate so it'll preload
Add the flexible coupling, leave a small gap away from the plate
add the 55 mm bolts to the motor, add to 40 mm spacers
wire going out this way
and install the motor and tighten the coupler
And its all together
