pretty solid
A project log for OpenBuilds C-Beamâ„¢ Machine Build
C-Beam Machine is a CNC machine design based on the popular V-Slot linear guide system.
charliexcharliex 10/12/2015 at 19:103 Comments
testing the linear rails with some weight
Max Williams wrote 01/13/2017 at 19:15 point
Did you consider using a Ball Transfer Unit instead of the rail?
charliex wrote 01/13/2017 at 22:16 point
i didn't , i had the rails lying around so used thouse
Max Williams wrote 01/14/2017 at 14:34 point
Ah I see. Thanks for sharing the project, it has helped me plan my C-beam build!
