SunStealer LED Grow Light Module
Networked LED strip for assembling multi spectrum grow lights.
Sunstealer is a 15 watt single color (rs485) networked LED strip built using a LT34781 driver and a PIC32MX110F016B. These strips are intended to be used to build larger LED panels with each strip covering a specific wavelength.
Strips (will) have string current and voltage sensing.
The goal is to be able to control the amount of light received by plants at each of these wavelengths and attempt to replicate some of the existing studies on type of light and it's affect on vegetative growth and fruiting.
There will be 5 variants of the strip each populated with LEDs targeting te following wavelengths (439,469,642,667,740) initially with the following ratios (1,1,2,2,1) This should make a 105w LED light for hydro/aquaponics.
shane kirkbride wrote 08/20/2015 at 19:43 point
This is a cool idea...
AVR wrote 07/25/2015 at 21:31 point
I want this for HydroPWNics!!!!!
