Board used in test setup
6 pin female header is used for microSD-pmod board, that was used to plug in UD-Card with SPI Flash.
The LED is NOT a power on LED, it is connected to FPGA I/O and is on because the FPGA has booted from the UD-SPI-Flash card. This SPI break out was used for development purposes. The ice65 UD card has on board SPI Flash too.
Antti Lukats
