UD-ice65 initial testing
A project log for UD Card with ICE65 FPGA
microSD Card sized board with ice65 low power FPGA
antti-lukatsAntti Lukats 07/25/2015 at 12:500 Comments
Board used in test setup
6 pin female header is used for microSD-pmod board, that was used to plug in UD-Card with SPI Flash.
The LED is NOT a power on LED, it is connected to FPGA I/O and is on because the FPGA has booted from the UD-SPI-Flash card. This SPI break out was used for development purposes. The ice65 UD card has on board SPI Flash too.
