DOLPi-UI Universal Imager Hardware Completed and Working
A project log for DOLPi - RasPi Polarization Camera
A polarimetric imager to locate landmines, detect invisible pollutants, identify cancerous tissues, and maybe even observe cloaked UFOs!
david-prutchiDavid Prutchi 10/18/2015 at 23:220 Comments
This weekend I was able to complete the construction and test of the DOLPi-UI imager. It is capable of viewing and polarimetric imaging in the IR-VISIBLE-UV bands. A FLIR Lepton module extends its imaging (but not polarimetric) capabilities down to the longwave IR ("thermal IR"). Raspberry Pi is able to simultaneously present the thermal IR image while acquiring images in the near-IR, visible, and near-UV ranges.
