Adding the SSD1306 OLED Screen to an Arduino Logger (without a library)
A project log for The Cave Pearl Project
Creating a generic data logging platform that is easy to build & modify for many different environmental monitoring projects.
ed-mallonEd Mallon 10/17/2018 at 19:320 Comments
This is the third in our series about using shift-out and unused analog lines to drive SPI displays. The primary reason to use this method is to save power in data logging applications that need to run for years at a time. When you drive the pin-power line down the screen is completely disabled and draws no current.
https://thecavepearlproject.org/2018/10/17/tutorial-adding-a-ssd1306-oled-screen-to-your-arduino-logger/
