And another one bites the dust...
A project log for The Cave Pearl Project
Creating a generic data logging platform that is easy to build & modify for many different environmental monitoring projects.
ed-mallonEd Mallon 04/06/2016 at 15:220 Comments
Just back from a fieldwork trip, and another of our temperature sensors has failed to go the distance in the underwater environment:
Field Report 2016-03-17: MCP9808 Fails Under Pressure
I've retired that generation of sensor caps and will likely go back to the waterproof DS18b's, some which have been running under water for more than two years now. (inside a stainless steel sheath)
