Screw Terminal Promini Logger
A project log for The Cave Pearl Project
Creating a generic data logging platform that is easy to build & modify for many different environmental monitoring projects.
ed-mallonEd Mallon 06/22/2017 at 00:540 Comments
While breadboard loggers are quick, the connections tend to be a bit too fragile for serious testing. So I've come up with a configuration based on a screw-terminal expansion board that breaks out all the pins nicely:
Arduino Data Logger: 2017 Build Update
As a bonus, I've also described modifications that bring this 4-part logger below 0.02 mA sleep current. Current assembly time for the basic unit is under one hour.
