Measuring Temperature with Two Clocks
A project log for The Cave Pearl Project
Creating a generic data logging platform that is easy to build & modify for many different environmental monitoring projects.
ed-mallonEd Mallon 02/10/2018 at 00:010 Comments
The resonators on cheap Pro Mini clones have so much thermal variation, that you can base a temperature sensing method on that alone:
https://thecavepearlproject.org/2018/02/03/measuring-temperature-with-two-clocks/
There is some rising/falling hysteresis that I'm still chewing on, and when I get brave enough to mess around with fuses, I'll re-try the method with the internal oscillator to see how that works.
