• ECG interface with Processing
    Dean Gouramanis07/28/2015 at 05:42 0 comments
    This Processing sketch receives the serial data from the HC-05 Bluetooth modem, and graphs it in real time.
    The MCU performs 10-bit measurements at a rate of 50ksps, and averages the result to obtain a 12-bit value. The PC receives a data point once every two milliseconds, which provides plenty of x-axis resolution.
    After 12 hours of programming, and excessive amounts of coffee, I think the data shows a heart arrhythmia.
