White light source
A project log for Color Sensor Flex Module
Advanced color sensor TMG3993
chris-hamiltonChris Hamilton 02/13/2017 at 06:440 Comments
I am curious if I can add a white light source with variable temperature. I expect it to be a RGB LED tuned to approximations of the K requested. I have found an algorithm at http://www.tannerhelland.com/4435/convert-temperature-rgb-algorithm-code/
